g20zoom
I'm in san diego,ca.
1955 duplex home, 1600 sf total
cast iron piping
built on slab
During the home inspection, we discovered that the back 2 rooms on one side has a higher moisture reading than other parts of the house. 1 room has vinyl DIY tiles that are all loose, the other room as laminate flooring buckling in a 4 foot area. I think the guy said 22% moisture...it was on the highest led from that yellow moisture meter.
The nearby bathroom was bone dry. It hasn't rained for several months and san diego is pretty dry otherwise...house gets pretty warm in the day, so it's odd the slab is so moist.
We've already invested quite a bit on the inspection but are thinking of walking now this big issue came up. we are torn since we do like the place alot.
What are some tests that can be run? what's the cheapest route to determine an issue?
I would hate to pay 250-400 for a sewer line cam...i just need to know if the sewer line leaks. we watched the water meter with everything off, and it didn't move in 15-30min....hence leaning to sewer.
I've hear that cast iron don't last...and given the age, and the 6 or so trees around the house(medium to large), i'm looking at worst case scenario.
Any rough idea what it costs to repipe the sewer lines?
Any ideas how to tackle this cheap?
Thanks!
cast iron piping
built on slab
Thanks!
