aurax
Hi,
I'm new to this forum and kindly ask your assistance with an issue i need to solve.
I need to mix water from two different water source - Reverse Osmosis and regular tap water.
The pressure/water flow changes over time (filter condition) and i need to keep accurate mixture of both water.
With you experience, what will be the most safe, cost effective method to do this?
I was thinking that placing pump after each feed will assure accurate pressure and simple mixing valve will do the trick.
Thanks!
Tal.
Thanks!
Tal.
