Ron6519
Researching tankless units. Seems with some of them, the gas meter has to be upgraded.
Here are the specifications:
Gas meter Information (off the meter label):
System Pressure 60psi
ANSI Class250 Model 250
Gas/air Capacity 250 196 CFH@1/2" WC
Tankless unit @160,000 BTU'S
Temperature rise from incoming water to 120 degrees F is:
55 degrees Winter
45 degrees Summer
Gas appliances in house:
Boiler 140,000
Hot Water heater 65000
Dryer 22000
Cooktop 5 burner 46700. Up to 30000 used at once and rarely.
Increase of 95000 btus from current hot water heater.
Added: Pipe(8 ft) from meter is 1 1/4" to 1" pipe
1" pipe for 8 feet, then 3/4" to boiler/hot water heater for 3 ft.
Thanks
Ron
55 degrees Winter
45 degrees Summer
Boiler 140,000
Dryer 22000
Thanks
Ron
