I have a 1950's house and the main gate valve will not shut off all the way. I read online that you can gently open and close it a few times to clear the debris. I did this a few times and the valve produced a couple drops of water. I am not sure where the water came from, but it worried me enough to stop. Is the water normal? Possibly from the stem that was emerged each time I shut it off? Or, is it possible the valve is starting to fail?
I would like to get this valve to shut all the way off so I can remove some galvanized pipe.
Any advice would be appreciated.
Thanks
Thanks
