furch
Hi all, I'm new to the forum and came on here because I've been pulling my hair out all day trying to fix our new jetted tub so my wife can take a bath.
It's a MAAX 54" corner tub, not sure the model as it came with our mobile home and I didn't get the specifics for it.
When the hot water is turned on, there is a leak from under the hot water faucet, inside the one-piece tub where I can't access it. See pic attached. Sorry for the crude drawn image.
The water leaks out from under the tub after a minute or so. I've disassembled the faucet and it looks like there is some pipe joint compound about 3-4 inches below the bottom of the cartridge.
The cold water faucet doesn't have this, and doesn't leak.
I've tried to remove the snap ring on the faucet and pull up the hot water line but it is attached to a bigger fitting just below the top of the tub, so it doesn't come up.
I've tried to access it from below the mobile home, but without cutting the floor there is no way to do it. Even if I did cut the floor, I would be reaching up over 3 feet into about a 4" wide opening so I doubt I could repair it from there.
Due to not being able to access it I can't see what the actual problem is . I was just about to cut a hole in the side of the damned tub when I figured I would ask someone who may actually know what they're doing.
Thanks for reading this, and ANY ideas would be greatly appreciated!
Furch
Furch
