dbaxley91312
We have a well and we have had sediment come up through our pipes a couple of times as the water is stirred up at the well. I knew this was the case so I decided to flush out our water heater. After I flushed it out, my water pressure for both hot and cold is lower than it was originally and if one faucet is running, it is extremely low if you use water at a different location. Any ideas on how to gain my water pressure back and the cause of the loss? I flushed a good bit of sediment out of the water heater, but it was all clear when I started to fill up the tank after the flush. I’ve also cleaned all of the aerators at the faucets. We have an electric water heater. Any help here would be appreciated.
