Yes the last time I did it I used a regular wax ring with flange. This time time I made sure to use a wax ring that is 40% thicker than standard and rocked toilet back and forth side to side gently. Sat on it and did the same thing, grabbed some 30lb dumb bells repeated. tightened bolts down gradually alternating sides hand tight first than with wrench, until washers started to bend a bit. Sat on it a bit then gave it an extra 1/2 turn. Also with my flange being a lead one if I over tighten I might bend it which might also cause a leak, right? Is there a set foot pounds to tighten the bolts to? I could get technical and use a torque wrench?
When I first had it leaking I did run red food coloring in the tank and bowl for a few days to check for cracks. I assume if there was a crack I would see a red line?
