Leak under faucet
tailgunner
Aug 18, 2014
63
22
Just noticed water leaking from under the loose faucet down to the cabinet below. Faucet was installed in a new construction home 7 years ago. It appears that there is no nut securing the faucet to the underside of the counter. Never saw a faucet installed like that.
I'm thinking that I will need to disconnect the supply line and install a nut , and possibly a large washer to secure it tightly to the underside of the counter? Is there a standard size nut, etc. Thanks for any input. Bob
    1.9 MB
Removed the plastic fitting from the bottom of the faucet . Found it installed upside down with the "wings" of the nut up inside the hole in the granite countertop . Am I missing something?Why do it this way?
Was the water leak just from water running under the loosely mounted faucet?
There is usually a thin plastic seal that sits under the whole faucet, to keep water from running under it.
Some faucets also need a layer of plumbers putty between the sink/counter and the faucet, as a water seal.
Looks like putting the black plastic retaining nuts on upside down was just a mistake.
They were probably able to tighten them somewhat by hand, but the wings are what give you a good grip.
you are right they are/were upside down there is a tool called basin buddy,it fits on the end of a socket wrench ,it witty over supply nuts,locking nuts,plastic locking nuts....good luck
Yea, the water was running under the plastic since the faucet was loose. Found out why the nuts were installed upside down . If installed normally , the nuts are too thick, or should I say the hot/cold threaded pipes coming down from the faucet are too short. So the plumber broke the wings off the nuts , turned them upside down so the thick part is up inside the two holes in the granite. With them installed normally , there is only two or three threads left to install the water supply lines. Bob
FYI: the plumbers putty I had said to not use on granite
You can get different putty that will not stain granite. Not oil based.
Or just use some clear silicone, if there is not a good sealing gasket supplied with the faucet.
Even with the plastic retaining rings mounted upside down, they can be tightened with a good size channel lock type of pliers.
