leak from leveling the floor
zephyrprime
Jan 18, 2016
6
I was jacking up my floor to level it. Well, what I didn't realize is that there is a drain pipe for the kitchen sinks right near where I was jacking. This caused a leak to develop. I backed off the jack and the leak went away for the time being.
The pipe seems to be threaded steel pipe bout 2-3" wide. I can see threads on the upper part of the section that is in the basement. Apparently there was a leak there already that somebody tried to fix with duct tape. The house is 2 stories with an attic. I would like to extend the length of the pipe a little bit so I can level the floor as I originally intended.
What do I have to do here? There is no easy way to unscrew the pipe that I can see. Should I just call a plumber? Should I call someone to do the floor leveling AND the plumbing? Who can even do both of those things? TIA!
If pvc the best replacement? Or should I try to use steel pipe? Would I have to put new threads on the cut sections? Can I solder steel pipe?
