s_petrucci
Hi there,
I am wondering if I could get an expert advice from you guys here.
This is my sad story: a while ago I removed the garbage disposal thing from my sink as I replaced two of them (each above 100 dollars) since they start stinking and we don't use it anyways! I did this little plumbing job to connect the 2nd small sink (used by the garbage disposal unit) to the main sink.
I think after it (if it is not a coincidence) my sink gets clogged all the time.
I used liquid, then took the U trap apart and it seems to be clean. I also used the cable but it doesn't catch anything.
After each time it gets clogged I use a plunger and it drains down well... for a few minutes only. Then it starts again.
I am wondering if you guys could take a look at my pipe work and point me at the right direction, please...
Thanks a lot in advance!
Cheers
Cheers
