copyman
Hi, New to forum.
Had a question on a Kenmore water softener. Unit is around 7 years old and has been working great until recently when I noticed the water wasn't draining and even overflowed from drain on side at one point. After Google search I tried everything suggested on different websites, cleaning venturi, checking drain hose, brine valve assy, salt bridge, etc. Nothing worked so went ahead and replaced the complete venturi & rotor-disc kit / seals with new genuine parts. Cam goes through all the cycles fine, adds water to salt level but water does not drain brine water.
Any suggestions greatly appreciated and thanks in advance.
Report Edit
Report Edit
