First, thank you for your response and advice but what if anything will the city water dept do? I did contact Rheem and they just sent me a replacement (magnesium) at no charge. I'm guess I shouldn't expect a differentoutcome. I'm assuming the new one will deteriorate just as quick as the original, correct?Anode rods typically come in three varieties, made up of three different types of metals: magnesium, aluminum, and zinc. The magnesium anode rod is the most common type of anode rod. The magnesium rods are best used in areas with soft water as they corrode easily.
What rod did you have, and which rod would work better for your water quality, is why I recommended to get the water company involved.
