Wet venting not allowed here but let's say I'm in a IPC area and wet venting is allowed
What if I had one vent for all 3 fixtures.
The W.C. requires 2" vent min. If I stack the tub and sink on the W.C. vent, Do I have to increase the vent to 3"all the way up to the sink? or just to the tub trap arm? I'm thinking all the way to sink.
i read an article that was about venting toilets with a 3/4 vent,Which is why I qualified my answer as being according to IPC.
Just to make sure that you are understanding where I am coming from.WC REQUIRES 2" vent, the lav is not relevant. The lave could drain on a 1 1/4 or 1 1/2 so upsizing from the 1 1/4 could be to a 1 1/2, but the WC requires a 2 in anyway. Therefore the question .. or atleast the most recent question in the thread is "do I need a 3" to the lav and then reduce it.
Answer 3" is not required
lav requires 1 1/4 but because it is wet must be upsize to a 1 1/2 BUT
since the WC requires a 2" it must to a 2" AND
above the lav under any circumstances it can not be reduced from what is below that level.
Yes?
Can anyone explain how to read flow vs pressure drop chart interference to sizing water distribution piping
I am basing my answers off of Florida Building Code, Plumbing. That code is based on the International Plumbing Code. If you are looking for UPC or SPC compliant answers, I am the wrong plumber to talk to.
With the code I work under, a toilet does not require a 2" vent.
And, once again according to IPC, once the trap arm of the fixture that is the wet vent attaches to the vertical pipe, the pipe above that point is a dry vent, and only need to comply with sizing requirements for a vent pipe, not for a wet vent.
Under IPC, the only instance (that I am aware of) that requires the vent pipe to be the same size as the drainage pipe is for the dry section of a waste stack vent system. Which cannot receive the drainage of water closets, so does not apply to the situation at hand.
