My father has a 50 gal Storage Booster attached to a coil in his oil burner. It was installed 5 years ago.
This weekend they had a bunch of guests over and after 5 showers the hot water was depleted and it took forever for any sustained hot water to return.
I went downstairs and took a look and the setup really confused me, then I looked at the manufacturer's installation manual and it left me more confused. His system was professionally installed but I can't make sense of the setup. Specifically it appears to me that there is no circulation between the tank and pump and I can't figure out the logic behind the circulation pump placement. Also, his setup has one output and two inputs, whereas the manual has one return and two outputs. Attached is the schematics and a diagram I put together of his setup, any feedback, input or suggestions would be appreciated.
