Is This a Noise Restrictor?
skeezix
Aug 24, 2019
228
68
Colorado
Before I replaced my hand-held shower head with a HammerHead I removed from it what I think is a flow restrictor. I also placed the head past a little valve so I could change the flow. When the valve is fully open, the shower is relatively quiet and as soon as I begin to restrict the flow to the head it gets pretty noisy. If I put the little restrictor back inside the head will the noise go away? Here's a picture of the restrictor (0.6" diameter):
It could, the water is moving slower through the restrictor and into the showerhead which could cause it to be quieter than the water moving faster without the restrictor.
So I put the restrictor back in and now I don't have any noise. The flow, while not as much as it was without the restrictor, is still adequate and I'm happy-happy!
On those restrictors I use a pick and remove the o ring but leave the green portion in the shower head
Are you referring to the teeny tiny O-ring that's inside the restrictor? What's its purpose?
I was wondering about that little 0-ring because it doesn't seal against anything when I reassemble the hand-held to the shower pipe.
Yes, that teeny o ring is a restrictor. Removing it is the happy medium, more flow but not as much as removing the whole piece.
