MaxPower
Hello,
I am installing an RO system. The instructions suggest drilling a hole into the drain and running the drain tube into the drain pipe. The house was built about 3 years ago; there is a garbage disposal.
However, I noticed this blue pipe and am thinking this is a discharge line for RO systems. Rather than drill the hole into the drain pipe, and hear the water trickle, I can just attach the drain tube into the discharge line?
I can't think what else this can be, other than some type of venting pipe?
The pipe is on the left of the cold water supply.
Thanks,
Max
Thanks,
Max
