It's like Flushmasta said, mine looks like the diagram. As far as seating, I think the joints are solid. I am tying into a 45 that drops inside the wall, where the 2" drain connects to the 3" stack via a 3 x 2 Wye.
To recap; there's a 2" trap with a 39" arm descending at a slope of 1"+ per foot to 2 street 45's, which go into the 3 x 2 wye.
The reason I'm having to drop it is because I'm in a 1940's house with 2 x 6 joists. The weir of the 2" trap is proud of the subfloor. In the shower, it's np, as I'll be pouring concrete for a shower pan, so IK can work around it. Once it gets out of the shower, I need it to be below the floor.
The only other way I could think to do it is to add 2 45's to the trap arm to dip it, which would essentially create two smoother slopes over the 39" with a dip. Is this any better? I have about 2' before it leaves the shower area.
The trap is 7", so can I go 14", then twist it downward to another, lower path with two 45s?
Alternately, can I add a vertical 2" vent inside the wall, go straight from the trap to the vent, then drop to the drain?
I would have to run the 2" vent inside the wall to tie it into the 3" stack.
Thanks again for all the feedback, I appreciate it.
Trying to do it right the first time.
