Mustang
Multifamily house; the plumbing for the 3rd floor tub/shower exists above the 2nd floor master BR. After tearing down the BR ceiling for unrelated reasons, I discovered that the 3rd floor bath has been leaking for a very long time (long enough to turn the piece of hardwood floor onto which the leak is falling black). The cast iron pipes still exist, but were replaced with ABS some time ago (I just purchased the 99-yr-old home in August).
It's a relatively modern tub (ex. not cast iron). The current tenant says the "tub" sometimes "makes a creaking noise." The bathroom has a splash guard between the wall and the tub, so water is not spilling over the side of the tub and seeping through the floor directly. I re-caulked where the faucet emerges from the wall, as that was loose...but the leak still exists.
It would appear as though water is somehow getting onto the top lip of the tub (in the wall), running to the front edge, and then running down the wood in the wall. Once the wood is saturated, the water starts falling onto the ceiling below.
My dad and I have had our heads jammed up into the floor looking for the leak for about 60 combined minutes so far with a variety of flashlights and groping around with our hands. I took a 15 minute shower while Pops looked/felt around, and he couldn't feel any water on the top lip of the tub (despite watching water fall at the same time)...so perhaps that theory is partially disproved. It doesn't appear as though any pipe is leaky, or that any part of the tub is cracked...
I've also recaulked the "splash guard," and the faucet's knob (as well as the faucet a 2nd time). I haven't yet recaulked the front edge of the tub, but again dad couldn't feel any water up there so I'm not sure whether that's worthwhile.
I'm at a loss. I'm trying to avoid calling in a plumber who also can't see any leak, and redoing the entire 3rd floor bath (or cutting a hole in the 3rd floor bedroom wall to access the back of the shower, as I have tenants there right now). Any ideas for other possible things to check, or solutions?
Attached is a rudimentary drawing...unfortunately I am without a decent camera right now.
