Instantaneous Electric Water Heater
alex7003
Active Member
Sep 14, 2022
28
Albany NY
Hi, I am wondering if any common requirements or best practice for a larger (e.g. 20-27 kW) instantaneous electric water heaters, similar to gas one? Does it require relief valve, check valve on supply and drain/service valves? Do they need water pressure tank? Installation manuals I could find address electrical wiring and refer to "local plumbing codes" for water connection.
Thanks!
Generally they require the same plumbing that a gas tankless would need.
I investigated installing one in a couple of different properties. It would have required installing some heavy gauge wire and upgrading the electrical panel. In addition, everything I read said the electric ones weren't that much more efficient than an electric tank heater.
