I just tried the faucet in the laundry room which is adjacent to the garage/water heater. A bit closer to the unit and has the separate hot/cold valves. The kitchen faucet is a one handle design. The hot water in the laundry room is coming out at 130F while the kitchen is at 120F. So this makes me realize the mixer valve thingies in the kitchen faucet may be diluting my hot water.
Then I tried the bathroom which is one room further from the heat than the kitchen, with separate hot/cold valves, and that hot water is only 120F as well.
Questions:
1) What would be "normal" measurement at inside faucet when thermostat is set at 140F?
2) What is normal heat loss in the pipes (CPVC)?
3) How much add'l heat loss when you go one room further?
