Wallyworldxoxo
Hi all,
So we had a new water heater installed on this 16 unit complex and now the pressure is lower on the hot side on all fixtures and it'll be high pressure sometimes then it'll start gradually getting lower and lower as I run the shower significantly lower then it dropped before under high use. Note I did not do this installation and two guys did this installation and I'm just trying to figure out the solution to this problem. I've checked all the basics no aerators are clogged the mixing valve has been replaced no tub spouts are leaking there's no major leaks in the system all valves are open all the way. I can't look at the water heater because it's locked behind a door now but I did see it what they did and I noticed that they put a thermometer on one of the inlet or Outlet pipes and also another fitting that look like it had some type of hot dog kind of end on both sides. They said that they did not reduce the pressure and I'm thinking that the piping was downsized that's reduce the pressure but I'm also thinking that maybe they did not downsize any piping because of the buildup of pressure that I get on the hot water side when I take off the aerator on the sink I can see that there's a lot of pressure. But I don't understand why I'm getting this gradual drop in pressure that significantly drops of hot water pressure to almost or I'm not getting enough water to wash off now. And all the basics of been checked like I said shower heads been taken off and checked even got the most lowest pressure shower head possible to get the most water out of it and I can still notice that I just don't have that powerful pressure jet of water like there was when the old hot water heater was on, and I talked to various hot water heater manufacturers and they said that there's no water saving device or restrictions on on water heaters at all and these guys came in and they installed a pump to to try to relieve this problem which you did pretty much nothing. So I'm thinking that you either the piping was downsized or the thermometer or that other hot dog looking fitting is reducing the pressure or there's a air gap in the system which I have attempted to purge in my unit by just doing the method of turning on the hot water side and capping it off and then gradually turning on the cold water leaving it like that for a while shutting off the cold water and then removing the cap and letting the hot water flow but I thought I had a stable pressure but then it started dropping again like it's getting just too much use to handle the demand of the building but it never had this problem before with the old hot water heater, so I'm thinking that maybe there's air trapped in the system since I'm in an upstairs unit on the very closest end of the loop to the water heater or the pressure relief valve is bad, or the expansion tank relief Schrader valve is bad because this evening are removed my aerator from the kitchen sink and turned on the hot and it blast it out full pressure but then it gradually reduced and reduced. Any thoughts? Thanks
