I just had to get my in ground pressure tank that is a shared well to 4 houses total replaced and the well guy recommended putting the pressure tank in the basement which I was fine with but now the pump is short cycling. Pump turns on below 50 jumps up to 70 then turns off and bounces below 50 to turn on again. It does this cycle about 4 times within 20 seconds. This was happening they about 9 times in 20 seconds they came replaced the new pressure tank and switch and now It’s better but still short cycling. I have looked online/forums and it seem the switch or pressure tank are usually to blame but my question is plumbing layout and size. There is only one pipe coming into my house that must be 1.25”-1.5” that adapts down to 1” from there it T’s to 2x 3/4” one side feeds my house and the other side goes to the switch the pressure tank and a spigot - they just moved out the spigot to attach the 90 gallon pressure tank. Could the short cycling be due to the pressure tank being adapted down to 3/4” and not having proper flow?
