I have a Delta roman tub faucet that has a leak under the tub that I can't stop. The leak is apparently from the spout. Leaks if I run either the hot or cold water; leaks if I let it drain or if I close the stopper. It has a hand held sprayer with a diverter valve built into the valve for the spout. If I activate the diverter the leak stops. The valve is a Delta 4707 and the diverter is built in the valve for the spout. When the diverter is activated the water travels to within an inch or two of the spout before it is diverted and the leak stops. This lead me to believe the oring was defective in the spout or the spout was damaged but I replaced the oring and the contact surface inside the spout looks perfect. I tried a thicker oring (same ID) and it got worse, I tried a thin line of plumber's putty in the spout to contact the oring but no change in the leak. I also confirmed the valve is installed properly in the tub. Nothing changed on the faucet but it just started leaking this week.
Did I mention that the tub is on two exterior brick walls and the other two sides are tile with no access panels. Not wanting to tear out any of these to repair the leak.
Anyone experienced this type of leak? Faucet is 11 years old.
