Our house was built in 2018. We have municipal water. For a couple weeks we've noticed a continuous humming sound from the water pressure valve area (pressure gauge--see photo marked in red) when we partially turn on the faucet and run the cold water. The noise ends when we stop the water flow. However, sometimes there's no humming noise if the faucet is barely turned on. For a couple days I've noticed the short hum right when we fully turn on the faucet. There's no continuous noise when water is running fully.
Today, the water pressure reading before and after flushing a toilet and washing hands were 56; 1.5 hours after doing dishes and taking a shower it was 56. Usually after we use hot water for doing the laundry or taking a shower, the water pressure could be around 70-80. One day it was at 100 after hot water laundry. Our A.O. Smith water heater has an expansion tank and sometimes it discharges water when we take bath or long hot showers. The T&P relief valve was replaced about 2 years ago when extensive water discharged from the tank after frequent hot water bathes due to leg pain. A.O. Smith recommended the replacement.
What went wrong? Should we lower the water pressure to get rid of the humming noise?
Thanks you.
Thanks you.
