How would you reconstruct this bypass valve?
amateurplumber
Active Member
Mar 10, 2013
29
I want to recreate this old bypass valve with ball valves (it has thread-less gate valves). Currently working on my soldering skills before I do this, but before I buy everything, I just want to make sure i have this right:
I need to solder a copper T on either side, then a piece of pipe going horizontally from each copper T to a ball valve in the middle, then another piece of copper going down vertically from each T, then a slip ball valve down from each of those, then a piece of threaded copper down from each of those. Is that right?
Next question: does a male threaded ball valve exist? If so, I could just solder that on to the piece of vertical pipe and eliminate the last step of soldering on the threaded piece of copper. But since I have no idea what I'm talking about, it may or may not be better to just do what I originally said (if a male threaded ball valve even exists :p).
Last question: should I first solder this all together and then solder each side to the two pipes? Or solder it together piece by piece?
Ok, thanks for reading...go easy on me!
They don't make copper to male threaded ball valves. Just use copper ball valves then use a copper x male adapter on the end of the ball valve.
John
