How to safely bend a faucet copper pipe
q0987
Jan 6, 2013
14
Hello all,
I ran into some issues that I need to more space to install the stainless steel water pipe to the faucet. My faucet cooper pipe is similar as attached image.
Is there a good way so that I can bend the copper pipe a little so that I can get some space to install the new stainless steel pipe?
I knew I can use some bending spring http://www.amazon.com/dp/B001AZYTWY/?tag=skimlinks_replacement-20.
The problem I have is that end of the copper pipe has a connector that prevents me from using the bending spring.
Thank you
The copper is very soft and by using both hands it is easily bent away from each other to make the connections alot easier.
Please see my updated real images.
After the installation, I can feel the hose that bends with quite force!
I installed the stainless steel hose a year ago without leak. On Saturday, when I cleaned the U-Pipe down the sink, I may accidently move the top connector and it slowlys leaks water. I tried to tight it up without success. Finally, I disassemble the connector and reinstall it. So far so good.
So I assume the space is too tight, any movement of the connector may cause leak!
If it leaks again, replace the supply line (stainless steel line). Just a helpful hint -- On some faucets you can connect the supply line to the faucet before installing the faucet , this help with tight spaces.
