how to remove this hose adaptor?
weilijd
Nov 2, 2016
5
It is leaking....
Looks like it's vacuum breaker. I just tried to remove it with a plier but failed....:mad:
Any tips to remove it?
to upload a picture from your pc
click manage attachments
click choose file
makke your selection from your pc/ click, ok/yes/uh huh/ or what ever you do on your end
then click upload
this is the part that most likely messed you up...you need to wait a minute,,
look above where you clicked "managed attachments" you will see your file # jpg when it is finished loading
close the manage attavchment window
click review or post reply
find on the side of the vacuum breaker a hole. with a pin in it. it lines uo with the hose bib threads
drill the pin out. it is a pita lock pin to keep you from removing it. i throw the damn pins away.
this is why i do,
