BetaRayBill
Dear Houdini,
Please have a look at the attached picture.
My well pump motor stopped working and needs to come out. I have a hoist strong enough to pull it straight upward, but I need advice about how to release the pitless adapter.
I started by screwing a one inch pipe with a T handle into the center of the round plate that is visible in the center of the picture. Pulled with impressive force, and nothing moved. Dared not pull harder. Removed the T handle, and made a picture.
The visible round plate is located three feet down inside a five inch diameter steel casing. The plate has two oblong holes on either side of the one inch female pipe thread in the center. One of the holes exits the wires for powering the pump. So, I am guessing that the other oblong hole has some kind of mechanism located down out of sight below that round plate which would act as a latch release. The problem is I don't recognize the round plate with the oblong holes. Don't know who made it, or the model number of the pitless adapter that must be sitting below the plate out of sight.
How do I release the latch?
