The drain pipe for my kitchen sink is leaking. My house was built in 1965. Everything is copper and brass. I am pretty sure the labeling on the pipe says it is type "DWV". Our water is VERY high in calcium, if that matters. I've lived here 30 years and have never been able to get the softener to work right. The pipe connecting the kitchen sink to the main sewer is in attrocious condition, but I can't find a leak anywhere else.
My main question then is: What is the expected lifetime of this stuff? I really can't afford to replace any more than that leaky section if I don't have to, but I don't want to be replacing little bits here and there for the next 10 years. Could that have been a bad section of pipe from the start?
The leak started the same time the outdoor fawcett on the back side of that wall started dripping. It has no shutoff. Then I thought it was a leaking toilet because all the water coincided closely with flushing the toilet. The hung ceiling hid what was really going on.
I'll explain some pictures. (1) is where the kitchen sink enters the basement. The bottom of the pipe is rotted there, and it continues like that for about 3 feet. The remaining pictures follow the pipe around. (2) is above the breaker box. Not quite as bad there. (3), (4) and (5) continuing to the right. That's the supply to the electric stove through the same holes as the pipe - how stupid is that! (6) is where it enters the basement bathroom. That framework is for the hung ceiling - hiding what was going on. (7) shows it entering the drain for the toilets. Shouldn't that cleanout be pointed up so the toilet water doesn't flow back into the sink pipe? (8) shows the first toilet and I think the vent through the roof. (9) and (10) show the second toilet. That strap on the right is loose. There's some spongy white and green mineral buildup and appearance of some seepage at a joint, but not to the point of dripping. (11) (see next post) shows the drains for the halfbath sink and bathtub. (12) and (13) are closeups. I believe all the water damage you see under the bathrooms are from sweating and occasional toilet overflows.
If it all has to be replaced, what is best, plastic or copper? Can all the brass fittings be reused? Please help! Thanks!
