samched
I am in need of pulling my submersible pump but am struggling to undersntad my well seal and how to get it off. See pictures below. Previous house owners built an addition over the well so the trap door is what I am working out of. The spilt-top well seal and bolts are very rusted to the point I cannot even begin to loosen the nuts without them rounding over.
To remove the seal, my GUESS is I will have to force the seal off even with the bolts/nuts tightened down. I started playing with this with a pry bar and started to get the one side of the seal to budge but didn’t want to push it. At this point I am thinking I have two options:
If I go with option 2, my tentative plan is to wrap some heavy gauge wire tightly around the drop pipe right underneath the elbow (see red arrow) and hook it up to a come-along to slowly lift on the drop pipe. My hope is this helps to lift the seal out of the casing as I am prying on it, and also act as a safety from the drop pipe falling down the well once the seal is loose. Also somehow glue or braze some sort of metal piece to each side of the seal and hook a safety line to it so I don't risk them falling down the well.
Any insight is appreciated or suggestions on better ways to handle this. TIA!!
- Keep prying on the well seal (the seal is slightly larger in dimeter than the casing, leaving a small lip to pry on) until it comes off and proceed with pulling the pump.
- Cut the plastic pipe going to pressure tank so everything is freed up, and apply upward pressure to the drop pipe somehow while simultaneously prying on the well seal.
