Hot water troubleshoot and recirculating pump question
wopachop
Active Member
Aug 3, 2023
32
CA
Ok dont laugh. Was with a restaurant owner at a local plumbing supply and the guy was super helpful. We bought the grundfos recirculating pump. Theres an upstairs bathroom where we planned to put the bypass valve. Now the funny part....we both thought he said the pump could be mounted right under the bathroom sink. Not sure why i didnt confirm. Thats like, impossible right? Supposed to be right at the heater on the hot side? Will it even work for this application since its 1" and the pump is 3/4". Wish i had looked at the heater before we went. We were going just for faucets. Pump was an add on.
The troubleshooting part. There was a community water heater. Some issue happened im not sure what it was. But the owner paid to have her own tankless heater installed inside the kitchen. She says its never worked properly. Just cant get hot water to the faucets. It takes forever she says. Was thinking about it this morning. Is it possible the guy plumbed it so that the hot water is still traveling all the way back to the original community tank location? Shes had professionals come test the heater and they say its ok. But nobody can figure out why no hot water to the faucets. We were hoping the recirculator will help. Now im worried its too small being 3/4" and the tankless is 1". Can i use the pump? I opened up the bags dont think i can return.
    1.4 MB
    1.8 MB
Check your pre rinse faucets make sure the hot and cold handles are always off when not in use, check your janitors closets if there is a chemical soap connection make sure the hot and cold handles are off ECO
LABS makes a fitting that threads onto the slop sink faucet that prevents crossovers it's called a side kick, check the easy stuff 1st
The best way to prevent crossover is to install check valves on the hot/cold on the piping feeding the pre rinse facet
Are there times a check valve is part of the faucet? Or always a separate device?
