We just moved into an old farm house.
It has an electric tank which is supplemented by our wood boiler during the cold months.
The issue: Hot water cools rapidly to luke warm. Has been like this since we moved in. Starts blazing hot and cools down almost instantly. It is as if the cold water supply is mixing in at the hot.
Cold runs in at the bottom of the tank, so there is no dip tube.
There is what appears to me, to be a bypass connecting the hot and cold directly above the tank. Is this normal? I feel like if I disabled (removed) the bypass pipe, it would solve my problem.
Would I be correct in doing so? And if so, why was it installed this way in the first place?
If I am incorrect, and this is a perfectly normal configuration, do you have any suggestions for which could help me solve this dilemma.
-fraser
-fraser
