Buddycot
Hi all, we are dealing with an electric water heater. The issue is this...
After no draw from the tank for some time, we run hot water (enough for a shower or to fill the tub) and it is really warm but not as hot as the setting on the tank. Then, after about ten minutes of the tank refilling after use, if we turn on the hot water tap again the water is really hot.
The issue is that after the tank sits for awhile the water cools back down to this really warm temp. Is it a cold water mixing issue? Heater element? Thoughts?
Thanks!
Thanks!
