eugstr
Hello, I know this is a common problem, but couldn't find the solution still.
I have a detached garage converted to a shop. A water line is running from a water tank 500 ft away under gravity in 3/4 pex pipe.
The flow is strong, and I have a booster pump right at the point the pipe comes into the garage.
The sink is a commercial stainless still sink with a commercial faucet with cold and hot regulators separated.
I've installed Stiebel Eltron mini 2 tankless water heater right under the sink. Just add a T to the cold water line to the heater and connected it to the hot inlet of the faucet.
I've installed the included flow reducer as it is directed in the manual.
When I open or close the hot faucet I hear the clicks in the heater, but the water is cold.
If I open the cold water faucet the water runs hot, in fact very hot, up until the booster pump kicks in and starts adding the pressure, and at that point, the water starts running cold.
I feel like the pressure is not right for the heater, but I'm not a pro, and couldn't understand what I should do to fix this.
Any advice is appreciated.
