I use a bell & Gossett series 100 hot water circulating pump to maintain hot water at the tap. The pump is set to come on in the morning and run until the thermocouple shuts it off after the pipe gets hot.
The pump is attached and mounted by the hot water tank drain valve. Hot water is circulated through the hot water pipes in a loop back to the hot water tank. The only valves available are the ones to isolate the pump for removal if necessary.
Recently, my hot water circulation no longer works. The pumps runs fine - but the pipe never gets hot. I suspect an airlock somewhere in the loop. My problem is how to flush the loop? I checked the pump (took it apart) and all parts are working (impellar, motor, seal, etc.). I was a bit ##@)_@# when I realized the plumber who designed and installed the system did not put any tap on the loop itself so it can be charged. I'm not sure how it was originally started in the first place to be honest - but it worked for 5 years.
Any suggestions for how to get rid of an airlock in this system? I tried draining the tank's pressure through the drain valve in hopes of dislodging the air pocket - but that didn't work. A friend suggested I bank the pipe with a ball peen hammer (shock wave?), but I hesitate to do that, might create a leak somewhere.
Thanks,
Frustrated in Houston ...
Thanks,
