Hot Water Circulating Loop
thompsdw
Oct 3, 2023
18
Utah
Hello everyone. We are moving to a different home and I am going to loose one of my favorite current home features. Our hot water circulation loop. Hot water is always very quick at nearly every faucet in our current home. The new home doesn't have one. I have yet to investigate if I can make surgical cuts in the basement ceiling and add one, but I wanted to get some advice on if there are any alternatives? I heard sometime ago about a device that passes hot water from the hot to the cold side of the faucet with a pump (Aquamotion). Do these work? Are there any other options, or is retrofit my only choice?
Simple reply, furthest fixture needs a tee into hot line, and ran back to water heater with circ pump.
Need a layout of how hot water pipe is ran.
Then we can help.
I'm not a fan of those cross from hot to cold pump. The true circulation loop is best
Grundfos, Taco, and Watts all make recirculation pump systems that work without a dedicated return line. Grundfos version is home comfort system. Dedicated is best but these work decent. Side effect is cold water will be warm when first opened.
