jjanders1979
Story: had home inspection (the first two pics attached), inspector noted the build up/possible corrosion on the hot/water inputs at top of tank.
We asked seller to have plumber come and inspect. They had Roto Rooter come out who said there is no leak and it just needed cleaning with a wire brush (second two pics attached). They left a bottle of Pipe Shield even though I believe that is for inside of pipes so not sure how that might help.
Tank was installed 2019 so pretty new and house was built in 2000 so also relatively new. Our worry is something caused that build up/corrosion and a simple cleaning isn't solving root problem.
Trying to understand if this could in fact be "normal" or we need to push back and get our own guy in there to take a look. Any thoughts from the group here?
