miamichillin99
This is my first post so please be kind. This is a great site so thank you to the admins and mods for supporting such an informative site.
I have water pressure of 90 psi measured using a Watts pressure gauge attached to a hose spigot. When I turn on any faucet or flush a toilet in the house the water pressure drops drastically to about 40 psi. If I turn on 2 faucets/toilets it goes down to 30 psi. 3 cold water taps and it's around 25 psi. All the cold water taps in the house and it goes to 19. Is this normal? I have a water pressure regulator, Watts N35B, which regulates between 25 and 75 psi but it had no impact on the 90 psi when I adjusted it. Strangely enough it did have an impact on the psi when at least one cold water tap is running.
Thanks in advance.
Thanks in advance.
