Hi,
I am in the process of renovating/rebuilding my main bath and ensuite bathrooms. In the picture you can see the 1 1/2"ABS drain pipe (on the right side of the picture - just above the PEX lines) protruding from the wall for the main bath (MB) vanity, which is on the other side of that wall.
On the left side of the picture you can see the current location of the 3" main vent stack which is in the ensuite bathroom. I am going to move that 3" stack over to the hole I have drilled out near the middle of the picture - which will be in a shower wall.
I intend to drain that MB vanity into the 3" vent stack once I have moved it....and am wondering how should I vent the 1 1/2" drain pipe from the vanity? I still have to drill all the holes to run the ABS over to the new vent stack location (still have to finish framing that wall as well )
Thanks
Thanks
