Hi, I recently took off my tub spout from my bathtub/shower unit and was in the process of reinstalling it. Anyways, the tub spout is secured to the copper/brass pipe (i don't know what kind of pipe it is) that comes out of the wall with a circular metal holder (don't know the name of this part) and set screw. I went to screw the set screw into the metal holder so the tub spout wouldn't rotate and I screwed it a bit tight, and the metal holder snapped in two. I believe it may have gotten weak with corrosion and mineral deposits and that's why it broke... plus I probably screwed it in too tight.
I have a couple of questions:
1) What is this metal holder part called?
2) Do they sell the metal holder part at Lowes/Home Depot/or general hardware stores?
3) Do I have to buy a whole new tub spout to fix this issue?
4) If I put enough silicone around the tub spout and let it dry, will that be enough for it to stay on tight? Are there any water issues associated with not replacing the meta holder, and finding another way to attach the tub spout? Or do I need to replace the clamp or tub spout all together?
I know this is a super basic repair, but I am no handyman and I also enjoy finding ways to fix my own things cheaply and efficiently. Thanks in advance!
