gregp553
Active Member
I drained my closed baseboard heat system to sweat in a new zone controller. When I tried to refill the system it seems that some water went in and then it stopped refilling. I can't seem to get water in. It's a well not city water with about 45 pounds of pressure. I can open the four outlets for each of the four zones and no water or air comes out. It has an Amtrol pressure tank. I don't think the individual baseboard units have bleeder valves. The system has a low water safety switch so I'm sure it won't run until the system can refill. Does that stop refilling the boiler? Also, it has a bell shaped pressure reducer valve (?) that from what I can read can help refill by lifting the handle up. Nothing happens when the handle is lifted up even though the water supply is open to it. Water pressure is normal throughout the house but I can't figure out how to refill my boiler. Water doesn't even drain from the outlet at the base of the boiler. What am I missing? I need some help
