After a few days of rain, my well suddenly began pumping a lot of sand and silt. It now completely clogs the sediment filter AND regular 30-micron filter after about 5 to 10 gallons of usage.
After doing some research online, I got brave and raised the pump up 4 feet hoping this would bring it above a pile of collapsed dirt. It didn't help at all.
The well is 280 feet deep. The 220 volt stainless pump is held by a 1.5 inch black poly pipe and tied to a nylon rope. I don't know the pump make/model. There is a 90-degree connector about 7 feet below ground level that heads off towards the house. The pressure switch is set to 40 on/60 off.
I'm not sure where to go from here.
What would be the best course of action from this point?
