Help identifying tub faucet brand
Jamie’s
Dec 7, 2024
Ontario, Canada
Hello everyone, I’m wondering if I could get some help trying to identify the make of the tub faucet in the pictures? It seems that somebody in the past had done a patch job to fix the handle and that patch job is finally given out. I now need to replace the faucet and I’m trying to match a new one with the existing fittings that are there so that I don’t have to start busting up the tile to solder in new fittingsIMG_0033.jpegIMG_0032.jpegIMG_0031.jpeg
What brand is the hand held shower hose+head, is the screw broken off in the handle, I wonder if there's I tiny drill bit and way out that could be used or, possibly cut a Phillips head screw,with a dab of super glue it to the remaining screw????
You are correct, the screw broke off about 2mm inside the square nylon piece. I believe with some work I can get that screw backed out.
