byoder7
I recently purchased a home and within the first two weeks a valve broke under the master bath sink. It leaked into ceiling below, bummer!! I suspect high water pressure caused the leak. I measured the pressure at 110 PSI - pretty high. I suspected the issue was the PRV (pressure regulating valve) had gone bad, so replaced it for about $1,000 (I know it's a ripoff). And made sure that my pressure stayed at the 55 PSI the PRV was set at.
But when I checked the pressure first thing in the morning it had jumped to 104 PSI! After doing a bunch of research I figured out that most likely cause was I needed a thermal expantion tank for the hot water heater. So I purchased and installed a WATTS PLT-12, and it is now installed. My baseline water pressure is 55 PSI, but now when I wake up the pressure still goes to 85 PSI, which I still feel is high. I was under the impression that the thermal expantion tank would ensure the pressure stays almost exactly at 55 PSI. I have replaced the thermal expantion tank twice, so I know that it is not broken, and it is precharged to 55 PSI as it should be.
My specs:
- PRV (pressure reducing valve) set to 55 PSI.
- WATTS PLT-12 thermal expantion tank installed on a "T" off the cold water line to the water heater. And this is "pre-charged" to 55 PSI.
- New GE 48 Gal NOx water heater.
- House built in 1997
My specs:
