Diehard
In Remembrance
As mentioned previously, "Back flow, by way of siphonage, from another apartment is very possible, when you have a loss of supply pressure." (Or back pressure.)
Chances are that the building is equipped with a backflow prevention device on the service entering the building, to protect the City/Town water supply from back flow from the building. Also, the plumbing codes do a good job of helping to prevent contamination of potable water due to cross connections with potential contaminates. However, it does not eliminate ALL the potential scenarios of cross connections and backflows due to back pressure or siphonage.
Here's is an example of how it can happen. Also, it's possible for a contaminate to enter the piping system from a lower lever and then when normal pressure returns, it can flow to a higher level in the piping system.
NOTE: This is simply showing what is possible anywhere and not necessarily what took place within the subject building.
