furiousman
I have an oil-fired, open gravity hot water system and would like to convert to a natural gas fired boiler, but unsure how to make this work efficiently. There is no separate hot water heater. everything is tapped into the gravity system! Hot water taps, inclluding the baths all tap into the gravity system. I am told to do the following:
-add a B&G pump (on the "hot" supply side) to add forced circulation.
-reduce pipe diameter on near boiler piping (to increase resistance for pump)
-Remove expansion tank and add compression tank
-add a bypass loop with mixing valve to preheat cold return as not to induce thermal shock in boiler.
But a couple of things bothers me.
In the summer months, to get hot water, I need to run the boiler. Noting the large volume of water to be heated, this is inefficient. How do I make this a more efficient process?
do I bother insulating the large diameter copper tubes that loop around the house?
Is there a way to get hot water where I need it without heating a massive volume of water?
Is it worth adding a highly-insulated hot water tank as a thermal reservoir?
Should i add two hot water boilers? One for the supply and one for the return?
In all, would love to know how to make my current system more efficient without tearing out the entire system.
