Another thought, if the float switches in the outside pit are not set correctly, the upstairs drainage pipe could sometimes be filled with water, and this might also cause your problem.
Hello all,
I'm Matt, live in Knoxville TN.
Here's my situation. I just bought a new house in March. The way the house is setup is that it's in a hill, so both the "upstairs" and the "downstairs" are ground level entries, front and back of the house respectively.
This means that the house requires a pump to pull sewage to the sewer, I think. The plumbing in the upstairs bathroom (street level) gurgles quite frequently and at times violently; sometimes the plumbing in the bathroom sink discharges whatever's in the p trap along with a nasty stench of the farts of a thousand dead cavemen.
I investigated a suspicious closed off "room" in the first floor by peering through the drop ceiling. I discovered what looks from afar like a 55 gallon oil drum submerged in the cement floor with two pvc pipes leading from it. Preliminary research indica t es this could be the pump, which acts like a tiny septic tank. Not sure.
Anyway, when this bad boy activates, there's usually a slam when it cuts off.
My question is what the heck is going on? None of the downstairs plumbing exhibits these issues. My upstairs toilet flushes sluggishly could this be the issue? Should I cut through the wall and clean the pump th I ngy?
If possible. Yes. But it may not make a difference. But that would be the least expensive thing to try first.
That discharge line above the check valve will be holding waste water so be careful.
Don't be that guy who disconnected the drain without de-energizing the pump.![]()
Hahaha yeah... so... how do I de-energize the pump?
