Rick L
- Joined
- Jan 12, 2025
- Messages
- 1
- Reaction score
- 0
i drained my water heater to do the routine maintenance. When i finished i attempted to refill the water heater. The water will only fill for maybe 2 minutes then stops filling.
when i have the water valve open it does supply water to the hot side with good pressure just (cold) but doesn't fill.
checked Pressure 55 PSI, changed water, turned off water to home opened all faucets. tried to fill water heater with a water hose still wont fill. I am stuck and hope someone could help me out with some suggestions on what to try next! thank you in advanced.
