Partsman41953
Hi all,
I have an Insinkerator Premier 3/4 HP disposal that is leaking at the sink. This was installed by me around 3 years ago. The leak must have been going on for a while but my wife did not notice it until yesterday. Anyhow, I have tried a number of times to try to remove the clamp but it is rusted to the disposal clamp. I tried spraying it with PB Blaster and let it sit for a couple of hours and them came back and tried to loosen the clamp with a small sledge hammer and it still would not budge. The only thing which I know to do now is to just cut the clamp off. I would like to still use the disposal as it is still working fine but I have no idea once I get it down from under the sink if I can separate the clamp.
I would like to know if there is a way to get the disposal out without cutting the clamp but if not is there a way of getting the remainder of the clamp off the unit.
If I have to replace it which brand and model would you recommend. My wife and I are only planning on staying in our house for another year as we are planning on moving.
Thanks
Thanks
