Okay guys. I got it working but have a question.
I checked the hose for any crack and it was perfectly fine.
Pulled hose out from inducer.
I straightened a big paper clip and cleaned the tube canal on the inducer all the way through, wiggled it around.
Next I checked the pressure switch by blowing on the tube, no click, no sound.
I'm not sure how hard I was supposed to blow but no click no matter how hard I blew.
I thought it was blocked/clogged there and inserted paper clip into the pressure switch itself, not too far but until I felt resistance.
I plugged back everything and voila, it works. My inducer motor probably is dirty.
I'll clean it before next cold season.
But I was concerned if I poked in the switch and closed the switch permanently.
So I pulled the cables out and tested the switch with a multi-meter. It was open or read 1.
I turned the gas off and turned the furnace on with the multi-meter still connected.
Inducer started running and after few seconds, multi-meter reading changed from 1 to some random number and then settled at 001.
When I turned the furnace off, it went back to 1.
Does that mean the switch is fine and I don't have to worry?
I can replace the switch if you guys think it's not safe. They are cheap.
Here's the video of multi-meter from open to close.
I started the video little late so it goes from open (1) to close quickly.
It goes back to 1 at the end when I turned the furnace off.
I again checked for click sound on the switch by blowing on the tube and still no click, no sound even when it's working and multi-meter shows it's opening and closing.
Is it very faint sound?
Thank you
